A few weeks back had to pull out the fridge when replacing counter tops. The ice maker had been working producing plenty of ice. After moving the fridge out and back it stopped making ice. Checked and there was no water being sent to the ice maker. Although we were not using the water dispenser on the door tried that and no water came out. Checked on line and saw the most common problems would be the water filer in the refridgerator side or the water control valve. Bought a new filter first and that did not slove the issue so bought and replaced the water control valve. there is still no water going to the ice maker or the door water dispenser. Not sure what to do next. Other than it not making ice and dispensing water it is working fine. Any suggestions will be appreciated.
