rodeojunkies
#1 Posted : Thursday, May 28, 2009 9:53:45 AM(UTC)
rodeojunkies
My counter saver has stopped heating but the light and clock still work. Is there a fuse that I can replace and where is it located?
#2 Posted : Thursday, May 28, 2009 6:39:48 PM(UTC)
Check the magnetron TCO (#1430 on the diagram) for continuity. replace it it's open.
Remove the wires from the high voltage transformer primary windings and check for 120VAC between them.
If there is no proper voltage then the control board has to be replaced.
If there is 120VAC then most likely the problem is a bad magnetron (#1428 on the diagram).
Here are the breakdown diagrams and Replacement parts for GE RVM125J02 | AppliancePartsPros.com
microwave oven Fuse blew, replacement blew too after 1'2 second. (Microwave Repair)
by paulmars 5/26/2022 2:21:47 PM(UTC)
Panasonic 1250W microwave oven (Microwave Repair)
by Guest 11/7/2021 5:13:30 AM(UTC)
No Beeping - Emerson Microwave Oven (Microwave Repair)
by Wkolosi 1/18/2021 4:08:40 AM(UTC)
Whirlpool microwave ovens countertop (Microwave Repair)
by boxershubhammm 9/23/2019 10:06:07 PM(UTC)
LG Microwave Oven (Microwave Repair)
by KJ43026 1/10/2018 4:53:45 PM(UTC)
Our Microwave Oven stopped working (Microwave Repair)
by Artista 12/26/2016 8:32:57 AM(UTC)
Microwave oven LATCH (Microwave Repair)
by MAKODOG 4/18/2016 5:32:27 AM(UTC)
by blbweston 4/21/2014 11:13:01 AM(UTC)
How To Change The Bulb In Microwave Oven Combo (Oven Repair (including Ranges and Cooktops))
by Lax21 2/1/2014 10:21:18 AM(UTC)
by JOSEPH MONNEY 11/13/2013 10:57:58 AM(UTC)
by JOSEPH MONNEY 11/13/2013 10:47:08 AM(UTC)
by johnny wen 6/20/2013 6:39:36 AM(UTC)
GE Profile microwave oven (Microwave Repair)
by alpinebucks 6/13/2013 12:47:08 PM(UTC)
Low heat from OTC Microwave Oven (Microwave Repair)
by Whirlpool OTC MicroWave 5/27/2013 2:26:18 PM(UTC)
GE Profile microwave oven - replacing the board latch (Microwave Repair)
by srduff1977 11/5/2012 9:46:52 AM(UTC)
