Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I was given the range no manuals or meat probe. The probe light blinks for the lower oven. I tried removing the plug out of the range. Tested each wire to ground and wire to wire and no shorts. I did not unplug the harness from the board and did not get any ohm reading wire to wire. Any ideas or am I going to need to replace board.
