jwayscue
#1 Posted : Monday, March 16, 2009 7:04:01 AM(UTC)
jwayscue
Ice maker will despence crushed ice ..but will not do cubed ice...burning smell..also noticed part of augor blade broke
woodchuckie
#2 Posted : Monday, March 16, 2009 8:10:51 AM(UTC)
woodchuckie
You have a solenoid switch It switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. See the diagram and parts list of the dispenser here. Replacement parts for GE GSS20IEPHWW | AppliancePartsPros.com
jwayscue
#3 Posted : Monday, March 16, 2009 8:49:46 AM(UTC)
jwayscue
nothing is moving at all .it is stuck in crushed ice position ..there are so many parts to go with this ..not sure what it needs..
woodchuckie
#4 Posted : Monday, March 16, 2009 10:20:19 AM(UTC)
woodchuckie
Unless you can see a loose wire connection on the solenoid and there is no noise coming from it when you try the dispenser, I would start with the solenoid.
SDTim
#5 Posted : Sunday, January 22, 2012 8:35:38 AM(UTC)
SDTim
I had this same problem but without the smell.
-remove the ice bucket
-in the rear on the left side you wil see a square hole where the metal rod from the ice bucket rests
-you should be able to freely move the actuator up and down, if not use a little up and down pressure until it frees up
Done, now it dispenses cubed ice!
GSOCSC
#6 Posted : Sunday, September 29, 2013 8:06:06 PM(UTC)
GSOCSC
Thanks, worked for me also!
Guest
#7 Posted : Thursday, October 28, 2021 7:55:58 AM(UTC)
Guest
Rank: Guest
United States
Carefully use a heat gun under the solenoid/auger motor panel to thaw out an ice build up.
Guest (4)
