Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Here are some HVAC Maintenance tips you should follow for the upcoming chilly days.
Joined: 10/25/2021(UTC) Views messages in topic : 0 Location: Martin
One peculiarity of domestic conditioners is that practically all models are not adapted for work in the wintertime. The working temperature range of the outside unit is usually from -7C up to +43C. Operation of non-adapted air conditioner in winter, first of all, reduces the service life of the compressor. As a result, it can jam. Besides, when you switch on the cooling mode of the air-conditioner, the condensate (water), formed in the internal block, cannot flow out because of an ice plug in the drainage hose. As a result, half an hour after turning it on, water from the indoor unit will flow directly into the room. Nobody wants an uncomfortable and an inconvenient life. So choose the right air conditioner Edited by user Tuesday, October 26, 2021 2:58:33 AM(UTC)
| Reason: Not specified
