Mid wash got code of SC. Drained the water and removed the rear panel. Disconnected the tube to the pump to release the rest of the water and checked for blockage at the pump, both hoses, and even checked the grey hose for obstruction. Nothing was obstructed and the water rushed out of the hose perfectly fine. I lastly removed the pump which appeared to be fine at first glane. The metal plate was hot even after not draining for 2 hours. Would this likely be the pump or is there another set of causes? Also does your site carry the replacement pump?
