Our washer is running great except for one thing....
Whenever it is filling with water, there is a buzzing noise. It only happens when filling. It appears to be getting the correct amount of water, as far as I can tell at least. But, I know that it should not be making a noise when filling and there should not be a pump in use during filling as far as I know.
Any and all suggestions welcome, of course. :)
Thanks for reading, Jim
Have this same problem! Washer was purchased with the house 7 yes ago, so have no idea if it was like this since it was new. Anyone have same problem?
It appears that the forum has died.
