moleson
#1 Posted : Thursday, September 16, 2021 1:48:52 PM(UTC)
moleson
United States
We have a Frigidaire side by side Refrigerator/Freezer. Model # FFSS2614QSO, Serial # 4A43100559, date code 08/14. We recently moved it from the downstairs bar area to our kitchen. It has an in-door water/ice dispenser. When we plugged it in, there was a spark at the outlet and then what appeared to be a puff of smoke that came out of the ice dispenser. The ice maker and ice/water dispenser do not work. It doesn’t appear that there is power to the dispenser unit. I also can't detect power at the solenoid for the water. The filament on the bulb looks fine but it won’t light. I also can't detect power coming to the light. The freezer works fine. Is there a fuse somewhere that I can check? What should I check next?
