Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi. I have a kitchen aid refrigerator with the above model number. I’ve recently started hearing a double clicking noise. It is coming from the inverter box area. It sounds like something is trying to turn off but quickly turning back on. Either the fan or the compressor. When I removed the back panel cover, the clicking stopped within a few minutes. When I replaced the cover, the clicking started again after a minute or so. It seems like it’s either an issue with the cover or maybe the heat inside when the cover is on. Any ideas ?? Thank you.
