Hello, I was wondering if I could get some advise from some experts.
I have a Maytag dishwasher that was working fine for about a month (I got it used), then it seems to have all of a sudden stopped spraying water to wash and rinse dishes. It will run thru the cycle as if it is washing. But everything is just as I left it, the dishwasher soap still intact.
I have taken it apart and cleaned out the garbage, and nothing major was found to be blocking the water flow.
Any advise? I was thinking it may be the Water Inlet Valve. But does that control the pressure enabling it to spray?
Thanks in advance. Harvey
