AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
fridge off in morning but another gfci plug is tripped---what causing this?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
my moms fridge has been off two or three times in the morning. on those mornings 3 different plugs have gfci tripped. as soon as its reset fridge works fine. have had an electrician look at it twice. changed a couple plugs but said breakers & box fine.
any ideas?
Get a GFCI that sounds an alarm when it trips. Consider that the ground fault is intermittent and only happens when the door is opening or closing or some function activates. I have similar problem identified as damaged wiring near where freezer door hinge is.
