Guest
#1 Posted : Monday, August 30, 2021 10:36:11 AM(UTC)
Guest
Rank: Guest
United States
The Icemaker overflows water into the Ice Holding Bin. This creates chunks of ice in the bin.
Ice gets jammed and can't dispense from the door.
Water also gets into the turning mechanism on the front part of the Ice Holding/Dispenser freezing it up as well. It started with just leaking into the bin.
I've tries turning the water down on the Ice Maker to input less water. Doesn't work.
