AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool Cabrio Washing Machine replaced transmission
Joined: 8/26/2021(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Delta, UT
We have a Whirlpool Cabrio washing machine that was making a horrible noise during the rinse cycle so I replaced the transmission and everything went together great. After the washer was hooked back up we did the recommended calibration as instructed but we still can't seem to run a load of laundry. In diagnostic mode the tank will fill, the tub will rotate one or two times and the water will drain but when we run a regular load the LED light never gets off the "sensing" mode. I don't have any idea what to do next, any suggestions?
Washer Repair
