AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I replaced the water filter with a new one. A generic bought from amazon but exactly as I have always used. As I screwed it in it made a loud vibrating noise. It stopped after It was all the way screwed in. I thought maybe I had not put this in correctly so I removed the filter and again on replacing it, it made a loud noise. I tried to get water from the door and only a very small trickle. I tried to replace with the old filter. It didn't make the loud noise but no water from the door. I tried to use the bypass plug and still no water. I'm not sure of which part to replace? Is it the water filter head and tube assembly/MWF manifold? or the water valve?
