Had a lightning strike near house, took out a number of appliances including the washer. The main control panel seems to work normally. I can select a cycle and press start, it will begin filling with water for about 5 seconds and then the valve shuts off and the machine just sits there. Does anyone know what a power surge is most likely to damage? I can't seem to find a timer in the parts list. Thanks!
