Hi!
I purchased just over 2 years ago a 30" Fisher Paykel Gas Range (Propane) and I always had issues with the broil burner. It's extremely hard to ignite it and very often, after a couple of seconds, it shuts off. When it runs, it's not heating very well at all. I've adjusted the oven dial with no real difference on anything for the broil burner.
Yesterday, I've changed (as a test) the brass injector for the broil burner from 1.00mm to a 1.36mm - it not starts right away, and the flame is very nice - albeit too strong.
I was wondering what are you thoughts in replacing permanently the broil burner injector to a 1.05-1.10mm?
Also, I have had a hard time finding those online. Any recommended online place?
Thanks!
