mlazzaretto
#1 Posted : Sunday, November 5, 2017 10:44:50 AM(UTC)
mlazzaretto
My DCS range was not igniting the burners very well, even after cleaning the surface ignitors and the burners. I replaced the re-ignitor and now the burners all light very well and the spark is strong, but the burners keep sparking after the burners are lit. Before I replaced the re-ignitor, the burners would sometime do this, but it would always go away after a minute or two of sparking. With the new re-ignitor, the sparking hasn't stopped even after 20 minutes. This is consistent for all of the burners. Help!!! Thanks in advance!
ThatGuy
#2 Posted : Sunday, November 5, 2017 1:33:04 PM(UTC)
ThatGuy
Groups: Expert
United States
A switch on one of the burners is sticking. This can happen if it had water in or it might just be bad.
GaFord
#3 Posted : Monday, February 5, 2018 11:54:17 AM(UTC)
GaFord
Was thanked: 2 time(s) in 1 post(s)
If you have a spark module that automatically sparks regardless of the position of the switch until the flame is detected and then stops sparking (like the RI-302, RI-324 or RI-326), but your spark module keeps sparking after the flame is lit, this could be a ground issue. The switch controls the amount of gas (how high or low the flame is) and sends a signal to the spark module that a specific burner is turned on. From an electrical standpoint, the switch is either on or off (there is no position on the switch that says “lite”). Once the switch is on, regardless of the switch position, the spark module controls the spark. The spark module will spark until a flame is sensed at the burner that is turned on. The switches are individually wired to the spark module so the spark module knows which burner to sense. Once the flame is sensed, the spark module will stop sparking. If you turn on the switch, gas is released and if the igniter starts to spark, you know the switch is good. The spark module then sparks all burners (safety feature) and continues sparking until a flame is sensed at the specific burner that was turned on. The flame is sensed using flame rectification (a process where the spark module senses the resistance of the wire in the igniter that sits in the flame, and the resistance of the wire changes when the wire is hot from the flame). The burner needs to be grounded to the chassis (the chassis is grounded to earth through the green wire) for the spark module to properly sense the flame and stop sparking after the flame is lit. If your burners screw into the cooktop, the burner is grounded through the screw which connects to the chassis of the cooktop. If the screw rusted (the screw may look fine from the top but could be rusted or corroded down below the burner where it attaches to the chassis), the ground connection can be interrupted. So if you turn on the switch and the igniter starts parking, the switch is good, and if the spark module lights the flame, the spark module is probably good. But if the spark module keeps sending sparks even after the flame is lit, you probably have a faulty ground. Make sure cooktop is unplugged. You need to remove or drill out the old screws holding down the burner (the screws frequently break when removing and have to be drilled out, you might need a slightly larger screw after drilling), sand out the screw hole, clean the burner, and put in new screws to re-establish the ground. If your module sparks with the switch in the off position, you have a different issue (probably water got into the switch and is completing the circuit so the spark module thinks the switch is on). In that case, you need to wait for the switch to dry (or gently use a hair dryer).
thanks 2 users thanked GaFord for this useful post.
miroho on 10/21/2020(UTC), bobbybus on 7/13/2021(UTC)
miroho
#4 Posted : Wednesday, October 21, 2020 3:40:20 PM(UTC)
miroho
United States
Read this and went to work thoroughly cleaning all of the burner mounting screws and that resolved the problem. TY
bobbybus
#5 Posted : Tuesday, July 13, 2021 7:02:07 PM(UTC)
bobbybus
GaFord...
Tks for that great info, it's the best info I've seen so far.
My continuity is ok on my five switch behind the knobs when I turn them on, my continuity is good between the ground and the burners, but still the clicking doesn't stop after the flame lit on the burner (flame is all normal) !
The only observation I see is that it seem's to have a little crack on the ceramic of the lighting electrode !
Could it be the little crack on one of the electrode that doesn't give the good resistance from the electrode to the module when the burner is lit so normally the module would stop sending the high voltage to the electrode or is it the Spark Module that is defective ???
Tks for all the info,
Looking fwr for the answers
