Hello,
I have a GE Profile model PFE28KSKESS. Just recently have an issue where water dispenser is barely dispensing water. The ice is also very tiny and producing at a much lower volume. I have checked water pressure at line-in and its fine. I have also changed the water filter. There are no kinks in the line. I was thinking that the water inlet valve may need replacing. However, I have the second icemaker in the freezer. Does this mean I have the dual water inlet valve or the single? Am I on the right track with the inlet valve? Any assistance appreciated.
Kind Regards,
Will
