Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I see lots of instructions for repairing the belt on Maytag dryers but none for the Maytag SG1000 which has a different configuration. The pulley is on a shaft between the motor and the blower. I assume I need to remove the blower to replace the belt? Edited by user Monday, June 28, 2021 5:41:40 PM(UTC)
| Reason: clarity
