Started a load. Filled as usual, than didn't do anything. After thinking it was a drain problem, we emptied all water, took all pieces out of center to check drain. Lots of soap buildup and a piece of melted plastic, never did figure that one out, may have been here when we moved in. Cleaned up all pieces and resembled, started and tub filled but would not switch to washing mode. Any thoughts??
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Having the same exact issue? Kenmore: Model# 665.13003N511 Edited by user Thursday, June 17, 2021 4:56:14 PM(UTC)
| Reason: Not specified
