Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
A shop vac worked for me. I just had to pop the top off and then went fishing. The tooth brush came out on the 4th try.
Rank: Guest
Technician said a screw was found and this caused my motor to break. I am puzzled how a screw got in my dryer cause it’s impossible cause I don’t have screws anywhere in my home.
Rank: Guest
Although it worked for the person involved turning the dryer over seems like a lot of lifting and hassle but if it works dont kill the messenger. I personally have taken the air chute off quite a few dryers not to retrieve something that had fallen down inside but to check and clean out the back end of the blower wheel. It can contain a lot of debris in the bottom also.
Rank: Guest
While cleaning the lint trap on my electric Amana dryer some straw from some blankets fell back into the lint chute. Should I worry about it starting on fire? And how can I clean it out?
