Hello,
The model number is: WM3987 HW Hard reset didn't work (pressing the buttons on the display panel for 5 seconds and plugging back in). I opened up the top panel and checked the noise filter input and output with a voltage tester pen and it seems ok. Also opened up the main PCB and nothing seems to be burned. One of the terminals out of the Main PCB (with 3 wires - red, yellow and black) seems to have power when using the voltage tester pen. The red LED light is not turned on.
Should I try replacing the Main PCB?
Thank you.
Groups: Expert
