I replaced the solenoids to the water and ice maker, still no ice. Purchased new ice maker and installed, still no ice. The water dispenser works fine. The solenoids are good. I have unplugged the refrigerator for up to 10 minutes and turned off the switch to the ice maker then back on, still no water to the ice maker. Any ideas on what i should look at next? The control board all seems to be working properly, as i can make changes and all lights come on.
I have same problem, it is broken wire inside the wiring harness at the bottom of the freezer door which goes up into the door behind the hinge. Check for continuity of the wires between the lower outlet under the fridge and the icemaker outlet at the top of the door
