Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi folks. I'm trying to replace the tub seal in a GE ge gtun275em2ww and can't for the life of me figure out how to remove the agitator. I've removed the small screw at the bottom of the agitator tube and have sprayed it with penetrating grease and applied significant amounts of leverage with a strap underneath attempting to pull it free but no luck. Is there a special trick to these? Any help would be much appreciated. Thanks in advance.
Groups: Expert
