My question is concerning the plastic plate that sits atop of the diverter motor shaft. It has a hole for the water to pass through and how do I know when installing a new diverter motor that the plastic plate's hole is correctly positioned for when the dishwater cycle starts? Can it be installed out of synch? Or does it correctly align itself?
