Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
We replaced a gasket underneath due to a drip. But on first run after reconnecting there was water pouring out the bottom of the door. The bottom seal is a hard plastic piece not a rubber seal. We removed door panel, removed and cleaned the seal. Water not leaking onto floor anymore but there is water in the bottom edge of the door panel. Is this small amount of water normal? Thanks in advanc for any response
