Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
When any regular cycle is started, the door fails to lock and code F26 flashes. The cycle does not run. But if I run the self-diagnostic, the door locks normally and the diagnostic cycle runs normally without any codes coming up. Any ideas?
