Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The display turns on like normal and selecting the type of cycle works fine. After pressing the start button there is the common starting noise (like the drain pump), followed by the lock of the door. Then the drain pump sound runs a bit more, the door unlocks, and then nothing. The washer just sits there like it's waiting for something to tell it to kick over to the next step of the wash.i cleaned the filter, checked for clogs in distal from the filter, replaced the door lock. Ran a spin cycle test, that worked. i tried running a drain pump test and got a 7r 14 code, but cannot find any reference to that as an "error code." stumped. Edited by user Friday, April 23, 2021 5:33:38 PM(UTC)
| Reason: Not specified
Joined: 5/1/2021(UTC) Posts: 0 ![Hong Kong Hong Kong](/Content/images/flags/HK.png)
maybe the drain pump get stucked by something? my washing machine has the similar issue, and find someone to checked the drain pump, found out there is something blocked the tube
