This unit has combined ice and water dispenser. The switch for dispensing these has failed and need to get the cover off to fix.
Can lever the top of the plastic control panel away (3 plastic clips) but that is all I can get moved... The sides and bottom are curved without any obvious (?) place to lever clips open without breaking the cover. No one has a video online for this model that we could find. Anyone know the clever trick to get this panel off?? Thanks
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Ditto: I'm having the same problem trying to remove the dispenser cover. Hopefully a video will show up!
