Hopkiba
#1 Posted : Thursday, April 1, 2021 4:55:23 PM(UTC)
Hopkiba
United States
My original evaporator fan burnt up. I replaced it with one from Amazon but while it ran, it was not strong enough to freeze the freezer section. I got the right replacement but when I plugged it in it would not run. Would turn maybe a 1/16 revolution when it should run. The leads to the fan motor measured 120V. I hooked up the fan directly to an outlet and it ran fine. Looking for ideas as to what the problem is.
