Joined: 3/23/2021(UTC) Posts: 0  Location: Orlando, FL
I have a GFD45GSSM0WW that when you start it after a few seconds it will pause. Sometimes it will restart other times If you push start it will start and pause again. a few seconds, 30 seconds, minutes in. Start, stop, start, usually the clothes will not dry.
All I can find is that the start/Pause button is part of the board.
It's not a heat or air flow issue as it happens when first started as well as after it has run.
At this point does board replacement sound like the fix?
Thanks, Ken
