Washer *sometimes* leaks
Hello, I hope I can help you with leaking a washing machine.
The best way to diagnose this problem is first to learn how water flows throughout the washing machine so that you can understand the weak points to check in your Washer.
Possible Reasons Behind Washing Machine Leaking Water
Is Your Washer Balanced?
Check the Washing Machine’s Door
Did you Interrupt the Wash Cycle?
Faulty Water Level Switch
Check for the Drain Plug
Check Your Hoses
Inspect your Pump for Washing Machine Leaking Water
Check the Water Inlet Valve
Check the Catch Basket for Clogs
Inspect the Tub Cover Gasket
