My FR28HMEDBSR/AA 4 door fridge flex door wiring is failing and I need help in how to remove and replace the harness. If I could get the harness out I can probably repair it and perhaps improve the area where it flexes to prevent future failures as well. I can remove the drawer and side rail to access the lower part of the harness, but I think it then goes inside the cabinet and runs to the back to the control board. I can't find any illustration of how to gain access.
Bump. This seems to be a common failure as factory harness is on backorder. Youtube has video of one guy doing a patch but poor quality and he does not R&R the part. Anyone?
