Our whirlpool dishwasher will fill with water and then just stop and click a few times and then just stop before the soap dispenser even opens. If I hit cancel/drain, it will drain just fine. In some cases, after filling you will hear a motor trying to start but it's skipping/grinding. Is this likely the motor/pump assembly?
