I went out last night to my garage fridge, (~ 40 F ambient)and my salad was frozen. Looking at the temp inside the door it was reading 28 degrees. That was confirmed this AM with thermometer.
GE Profile Arctica Model # PSC23NGPA BB
Freezer works fine, temp is about -2F. After taking the back plate off I noticed the fan on the coils runs constantly, I don't know if this is normal or not.
I set the temp to 45F and it still cools down to 28F.
Any ideas on where to start? Usually when fridges die they go to warm, this one is different enough there isn't a lot of info available on the web.
TIA
bob
After muddling my way through the teardown it is the damper door coming from the freezer. Now to make sure I get the right one. I am going to try JB Weld on it for now until the new one arrives.
bob
Once removed it was a simple job to get to the damper door. The flap was broken from the shaft that opens and closes the damper door. I repaired with JB Weld and let it set overnight. Overnight I taped a piece of folder paper over the hole from the freezer into the fridge with just a tiny opening for the cold air to spill over. The fridge stayed at 37 degrees all night. Upon reassemble the door worked just fine. Until the new part arrives I believe this will work just fine.
bob
Groups: Expert
Good job. This web site is mostly dead. I stop by maybe once a week, but usually don't answer if I'm not sure about the solution.
