Here is a recording of my Whirlpool dishwasher (wdt920sadm0): recorded dishwasherThe dishes look clean, but there's still soap on them. We have to run them under the tap to wash off all the soap slime. I took out the filters to see if they were clean (they were pristine, as we pre-rinse everything before loading the dishwasher), and felt around in the filter pit to see if I could grab anything that was rattling around in there. No dice. I took a guess that the drain pump was bad, so I replaced it. The noise is still there, and the soap slime too. This time around, I'm asking around to see what people think before spending more money on parts. This dishwasher has two pumps. I can replace the other pump next. What do you guys think?
Guys, I'm going nuts here.
I replaced the main pump this time. Noise is still there. Does anyone have an idea?
Any ideas are appreciated. Thanks in advance.
Bump.
Has anyone had a dishwasher make a similar noise?
We had a similar problem with our Bosch dishwasher. We called the local services but they have not found anything. This noise was so annoying that we have decided to buy a quiet dishwasher . Have bought GE Profile 24″ Stainless Steel and forgot about the noise.
