Rodents chewed the hose from the dispenser to tub, I can’t locate a replacement tape is not holding up. That little turd took a bite out of every hose while it was in storage. Drain hose, pump to drain, the one that goes to the bellows, the three going into the dispenser. I guess I’m lucky she only chewed one wire. Thanks in advance!
