anselgreg
#1 Posted : Tuesday, May 26, 2009 2:40:36 PM(UTC)
anselgreg
My dryer seems to be taking 3-4 cycle to dry clothing lately do you think it is the element or something else? Also when I try to look at the ele. diagram I am unable to read it is there any way to get a larger copy.
sidfink43
#2 Posted : Wednesday, May 27, 2009 6:11:11 AM(UTC)
sidfink43
Hi Anselgreg
Here is the frigidaire site that will have your wiring diagram, parts lists and other good stuff.
http://www.frigidaire.com/manuals.aspx
As far as your lack of drying is concerned, if the machine is heating, and tumbling and air is being blown through (and it seems like it must be if the clothes are eventually getting dry) then the problem is most likely in a restricted venting situation. You need to tear down the dryer part and thoroughly check and clean out everything and be absolutely certain that there is nothing obstructing the flow of air. At the same time check the heating element for a break or for continuity.
That should fix it, but if it does not post what you find and we will see what else we can come up with.
Good luck, and let us know the results. This is a good and expensive set so we hope you can keep it going!
anselgreg
#3 Posted : Wednesday, May 27, 2009 4:12:45 PM(UTC)
anselgreg
I will give that a try this weekend and let you know how it goes, Thankyou for your reply
Low heat setting too hot on admiral dryer (Dishwasher Repair)
by Guest 11/20/2021 8:15:15 AM(UTC)
Low heat on Whirlpool thin twin electric dryer (Dryer Repair)
by lotusTT 12/2/2018 4:06:08 PM(UTC)
Whirlpool Dryer Has high heat but not Low heat (Dryer Repair)
by pjineson 6/26/2018 6:44:33 AM(UTC)
Kenmore 61262 only runs in low heat (Dryer Repair)
by Jonas76 5/11/2017 2:57:39 PM(UTC)
Dryer only heats on low heat cycle (Dryer Repair)
by PaulieM 11/21/2016 6:11:59 PM(UTC)
Maytag Gemini left rear burner stays on very low heat (Oven Repair (including Ranges and Cooktops))
by hh1126 5/12/2016 11:42:55 AM(UTC)
dryer no/low heat (Dryer Repair)
by scottfred3 12/10/2014 3:29:11 PM(UTC)
Jenn Air Cook top Low heat (Oven Repair (including Ranges and Cooktops))
by Curban 9/29/2014 12:14:42 PM(UTC)
Dryer turn on, rotates but won't blow heat! (Dryer Repair)
by Dmartin2390 7/7/2014 5:00:09 PM(UTC)
Low heat from OTC Microwave Oven (Microwave Repair)
by Whirlpool OTC MicroWave 5/27/2013 2:26:18 PM(UTC)
Upper Oven Slow Heating (Oven Repair (including Ranges and Cooktops))
by jesavage 5/13/2012 1:30:01 PM(UTC)
High heat only, no low heat? (Dryer Repair)
by Maytag junky 4/21/2012 8:09:20 AM(UTC)
only drys on LOW Heat (Dryer Repair)
by saraheyz 4/16/2012 8:05:35 PM(UTC)
dryer not heating on low heat settings (Dryer Repair)
by hdf150 3/17/2012 2:35:32 PM(UTC)
Kenmore series 700 gas dryer (Low Heat) (Dryer Repair)
by jcspahr 12/19/2011 6:06:36 PM(UTC)
