mbferland
#1 Posted : Monday, January 4, 2021 10:56:01 AM(UTC)
mbferland
United States
I had a new ice maker assy installed Dec 30 (by Sears tech) who also melted and removed the excess ice that had built-up around the evaporator behind the lower interior freezer panel. Now the fridge compartment is not getting cold enough. Fridge is set at 36 degrees but I'm seeing 44 - 49 degrees in the fridge compartment. The freezer is plenty cold, down around 0 degrees and ice is being made.
Where is the temp control (thermostat?) located for the fridge compartment?
