I will try to keep this short. Wife set oven to clean. Woke this morning with no clock on oven. I checked breaker (ok), pulled oven out. Found burnt wire on lower element on upper oven and loose nut on black wires on terminal block. Block broke put bolt through wires and have 120v on both legs but display is still dark. Looking for wiring diagram and guidance.
Groups: Expert
https://www.appliancepar...irlpool-kebi271ybl1.html Part no. 20 is called a thermostat , but I'm betting its actually a thermal fuse that is open. Also there might be a thermal fuse inline to the computer. Either one could stop power from getting to the computer.
