Joined: 12/6/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN
Kenmore 600 Series Washer Model Number: 110.27612600 SN: CU0640591
I replaced the clutch assembly in my Kenmore washer. The clutch had the blue spring installed and an extra green spring was supplied. Which is the correct spring for my model?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
If your machine is a full size one, the blue one should be correct. If I remember correctly the green one is for the stacker model. It should have come with instructions that told you which was the correct one.
