Hello all. I appreciate you taking the time to read. I have a PLCF489CCD dual oven. The right (standard size) oven decided to stop heating correctly on Thanksgiving. I have replaced the lower heating element, as it was not operating.(Cold to touch) That did not fix the problem. The upper heating element operates as normal, and the temp switch is operating as normal as well. I can only guess because the temp display does show some heat when I operate the left smaller oven. Everything is operating correctly on the left auxiliary oven. The relays do click on/off. What would the next piece be to check. I do have a DVOM, and wiring diagram. Should I look at the interface board? What is the voltage at the connectors to the lower heating element P9 (Y-6)*? Thank you all and stay safe
