Nitro itch
#1 Posted : Friday, October 2, 2020 11:48:43 AM(UTC)
Nitro itch
The original board had the typical water switch 3 wire harness (pink-violet-brown) harness soldered to the board. The new board has only two male spade terminals for the water level switch to attached. So I am not sure which wire goes where and what to do for the third wire. Any help is appreciated.
