I have a gas range / oven Model No. KGSA906 PSS02 Gas Oven and Gas Cooktop
Recently the power was lost completely to the display panel. Several months prior I had replaced the keypad and it seemed to work fine. Occasionally the oven would shut off (power) but would turn back on after a few minutes (after it cooled down?) and i could turn it back up and continue baking
I assumed that since the key pad had recently been replaced that this might be a control panel issue. I ordered a new control panel and installed it But it never lit up or showed that it had power.
The breaker is fine and I have tested the outlet and it reads that it has power. I’m thinking that it is somewhere between the power cord and the control panel.
Wondering if there are suggestions as to what to check next or is it time for me to call someone to come in and fix it.
The gas range has always continued to work and the electric igniter works for the cooktop.
Any suggestions would be appreciated
Rob
