Joined: 7/17/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Richmond, VA
I have an E11 error.
Ran test. Got Error some times.
Odd because it depends on mode. If I don't put extra rinse I don't get the error? Seems to only work on eco mode?
I tested the fill valves and all seem to be working.
Took apart the pump and found a nickel and this think piece of metal. Is that a part to the washer? I cant tell?
[img=https://imgur.com/a/MJWv8oY]odd part[/img]
I have a control board on order should I try that? Or is it this odd part I found in the coin trap?
Update that is part of a bra. Guess I need a new control board?
