Looks as thought the coldest I can get this is +10 degrees F, even though the display temperature on the door suggests it-4. Dont know if its the Inverter control board, temperature sensor, thermistor . freon leak, somethign else??? UNit is 8 years old and is Samsung RFG293HARS/XAA
Frig is fine
Thanks everyone
