Can anyone provide info on how to remove the panel to access the accuator for replacement. The lever has broken off my unit and needs replaced. Does the front panel simply pull off? The replacement part "looks" like a simle fix. Thanks
Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Thanks so much for your assistance! Have a great day!
