zoomjohnny
#1 Posted : Tuesday, June 9, 2020 1:55:07 AM(UTC)
zoomjohnny
United States
Hello,
I am getting a steam sensor error message on an older GE Microwave PVM1870SM3SS
I had a prior problem which I just fixed. I replaced the control panel, Thermostat, all 3 door switches and fuses last week. Did i put something in wrong? Everything else seems to be working properly. I never received this error message before and this function was not an issue until after I repaired these other items. When I press One touch vegetable button it starts fine then after running for about 15 seconds it stops and display's "Open- Steam Sensor- Service may be needed" message on the dislay. Looking at the parts diagram I do not see a steam sensor. Is there a steam sensor or is it called something else. I would appreciate any guidance.
