Water pooling up underneath the pantry drawer Most popular cause is freezing of the drain tube behind the panel This was unfortunately not the case for me Draining just fine through one tube into the evaporator pan / Don't know where the center drain tube leads to inside unit? Water reservoir in back left is fine too with no leaks I've shut off water to the refrigerator and relieved the pressure - water still collecting slowly underneath Appears to be coming from somewhere in the center Not sure if it's a heating element for condensation behind center or not? I'm a plumber and pretty handy so any help would be greatly appreciated - Thank you
Edited by user Monday, May 25, 2020 2:11:11 PM(UTC)
| Reason: Not specified
