Joined: 4/19/2020(UTC) Posts: 0  Location: North Carolina
I have a Frigidaire wall oven model FFEW2725LBB. Normally when I press the bake button, it comes on and swithces to the default temperature setting in about 20 seconds. Today it comes on and runs for 20 seconds but never switches over to the default temperature setting. It just turns off. I turned the circuit breaker off & back on to reset the control panel. That didn't fix the problem. Any suggestions as to what is causing the problem? Could it be something bad on the control board or a bad relay somewhere? Edited by user Tuesday, April 21, 2020 8:00:21 AM(UTC)
| Reason: Clarification of problem
